Activity Forums DaVinci Resolve Resolve Running Low On Memory
  • Resolve Running Low On Memory
    Posted by Dave Williams on September 12, 2012 at 2:57 am
    Hello
    Lately I have been experiencing a warning of “Resolve is running low on memory” If I say Ok enough times it eventually crashes. I use to be able to load 2 or 3 hours of footage with some rough grades and no problem.
    I have now experienced this with a 60 second spot with only the selects imported in. I am now experiencing it on a 48 minute show with only the selects which are cut to fit. The show is all prores 422. I am running 8.2 and cannot bump up to 9 yet. I have 2 Quadro 4000’s and a red rocket card. Running on a 2011 Mac pro with 24 gbs of ram.
    Any suggestions or any thing that would help would be appreciated.
    Sascha Haber replied 13 years, 11 months ago 4 Members · 4 Replies
  • Juan Salvo
    September 12, 2012 at 3:01 am
    What os are you running? re you usi any other apps?
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Dave Williams
    September 12, 2012 at 3:04 am
    Running 10.6.8 and there are no other apps running.
  • Teo Rižnar
    September 12, 2012 at 6:00 am
    This error was common in V8 if you had a big project. for feature films if you didn’t split reels/sequences in different projcets it was “out of memory” all the time. But in V9, I am handleing same big projects and even bigger ones and there is no more problems!
    Are you running V8 or V9?
    Color grade reel: https://vimeo.com/15480583
    Cofounder of https://nuframe.si postproduction
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Sascha Haber
    September 12, 2012 at 6:29 am
    Do to the nature of Resolve being a 32 bit application, there is nothing you can do.
    You need to get 9 to use more RAM
    Or work in proxies if you raid allowed DPX playback
    A slice of color…
    DaVinci 9b3 OSX 10.8
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    Colorist / Aerial footage nerd
    https://vimeo.com/saschahaber
