Activity Forums DaVinci Resolve Resolve render shorter clips than original!
  • Resolve render shorter clips than original!
    Posted by Hal Ray on March 1, 2016 at 6:37 pm
    Hello,
    I need your help.
    This is urgent.
    I exported a finished timeline from Final Cut X to Davinci Resolve 12 via XML (XML v7 I think).
    then graded in davinci resolve and export final cut round-trip preset with individual clips setting. (DNxHD 180 MOV format)
    FCX won’t open the xml file.
    I had to manually insert the graded clips to the timeline but found that all the clips are a bit shorter than the original clips!!!
    I have few clips that are full second short and thus not usable!
    the project shot with BMCC, go pro 3 and sony rx100 m2
    what is wrong?
    Please I need your help as soon as possible.
    Eli Bierwag replied 10 years, 6 months ago 4 Members · 3 Replies
  • David Roth weiss
    March 1, 2016 at 8:07 pm
    Possibly a handles issue. Check your handles setting in Resolve – maybe it’s not set, maybe it’s set too high or too low?
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Glenn Sakatch
    March 2, 2016 at 3:24 pm
    Do you have consistant frame rates between projects?
    Glenn
  • Eli Bierwag
    March 3, 2016 at 5:57 pm
    Definitely check the handles and the project frame rates as mentioned above.
    Having good sized handles is particularly important if you have done any time remapping. There is always a chance for discrepancies between Resolve and your editing software when it comes to time remapping/warping. Having a decent handle length (I use 2 seconds) generally avoids these issues.
