Activity › Forums › DaVinci Resolve › Resolve re-names stills when importing by adding brackets and duplicating numbers in the original filename?
  • Resolve re-names stills when importing by adding brackets and duplicating numbers in the original filename?
    Posted by Jeff Sargeant on November 1, 2017 at 7:41 pm
    Re-naming stills when importing by adding brackets and duplicating numbers in the original filename? Is this a bug, it’s not good when having to re-link files, it can’t find the originals.
    Jeff Sargeant
    Videographer @
    Flowmaster/Hurst/B&M
    Hayden, ID
    Michael Gissing replied 8 years, 11 months ago 3 Members · 3 Replies
  • Tero Ahlfors
    November 1, 2017 at 8:12 pm
  • Jeff Sargeant
    November 1, 2017 at 8:26 pm
    Thanks, that just confirms that this is a bug that needs to be fixed! There is no reason to re-name .png or .jpg files that are not in an image sequence. It’s extremely annoying having to flush this out when time would be better spent on creativity, rather than file management because of a bug.
    Jeff Sargeant
    Videographer @
    Hayden, ID
  • Michael Gissing
    November 1, 2017 at 10:10 pm
    Actually it isn’t a bug but a behaviour designed to recognise image sequences and deal with them as a single file. Otherwise image sequences like the ones shot cDNG would be an absolute nightmare. That’s why you need to select show stills as individual frames before importing. How else should Resolve deal with this conundrum?
    Yes it’s a tad annoying but I just ask anyone making graphics or producing stills to avoid using a number at the end of the file name. It happens from time to time and when I see that behaviour, I delete the files in the bin that are not actually image sequences, tick show as individual and reimport just those bits. It’s not actually renaming anything at the file level, just displaying the range of the image sequence.
