Activity Forums DaVinci Resolve Resolve Playback Problems with 12bit HD-SDI out
  • Resolve Playback Problems with 12bit HD-SDI out
    Posted by Florian Martin on February 21, 2020 at 9:34 am
    I am facing problems playing back footage with an older Linux Workstation. I am playing back 4k TIFF 16bit files from an internal RAID. The playback is fine with HD-SDI out set to 10bit ( RGB 444 4096×2160 ) and the machine sustains 24p playback. So it is probably nothing related to the file reading and opening part. As soon as I switch to 12bit HD-SDI the machine plays around 21 frames. What could be the limiting factor ? CPU, memory, GPU, HD-SDI board. The machine is equipped as follows:
    Supermicro CentOs 7
    Resolve 16.1.2
    2x 3.1 GHZ 8core Intel Xeon
    32 GB RAM
    2x Nvidia Quadro P6000
    Decklink 4k Extreme 12G
    Kind Regards,
    Florian Martin.
    Florian Martin replied 6 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
