Activity Forums DaVinci Resolve Resolve on Win – Performance Lack with Waveform-/Vectorscope-Monitors on
  • Resolve on Win – Performance Lack with Waveform-/Vectorscope-Monitors on
    Posted by Alexander Falk on May 16, 2012 at 6:55 am
    Hello,
    i started Resolve on Win with one Quadro5000 for GUI and GPU. Works okay.
    I add a Quadro400 for the GUI, to use the quadro5000 for GPU-only. If i then turn on Scopes it drops down to 2-3 fps playback without any corrections applied. If i close all scopes it runs with 25fps.
    I then add a Quadro4000 for the GUI, but it was the same, which doesn’t make a sense to me!
    Slot configuration is correct. All drivers and setup files as recommended in the configuration guide.
    If i run Quadro5000-only it runs 25fps with scopes and corrections applied. Really doesn’t make any sense to me!
    Any clues?
    Alexander Falk replied 14 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
