Activity Forums DaVinci Resolve resolve not fitting my 17″ MBP screen
  • resolve not fitting my 17″ MBP screen
    Posted by Ryan Wu on January 11, 2011 at 7:07 pm
    I have been trying to figure out how to get resolve UI to fit in my 17″ mac book pro display. I’ve searched around but no luck yet.
    It must be simple something I’ve overlooked.
    Can anyone help out?
    Ryan
    Andrew Hills replied 14 years, 6 months ago 5 Members · 7 Replies
  • 7 Replies
  • Dwaine Maggart
    January 11, 2011 at 7:32 pm
    The Resolve GUI is designed to run at 1920×1200 resolution. A 17″ MacBook Pro should normally support that. Is your display resolution 1920×1200? If not, and it won’t run at that resolution, the next best alternative is to connect an external display that can run at that resolution.
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Ryan Wu
    January 11, 2011 at 7:55 pm
    that explains it
    nope my older MBP only goes as high as 1680 x 1050
    hhhhmmmm
    rats
  • Luke Maslen
    January 11, 2011 at 11:41 pm
    Hi Ryan,
    Please download the DaVinci Resolve for Mac Configuration Guide and review the Building a Resolve MacBook Pro section. This section details the MacBook Pro models we have certified for use with Resolve and will hopefully answer most questions you might have about how to make Resolve correctly on your Mac.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Taj Jackson
    January 12, 2011 at 1:05 am
    Hey Ryan, You might want to try this work around if you really have to use it.
    https://forums.creativecow.net/readpost/277/3018
  • Andrew Hills
    February 16, 2012 at 6:43 pm
    Hi I’m running my MBP 17″ @ 1920×1200 and I had been using my external monitor. All was running well, but now that I have unplugged the external monitor to work away from home, Resolve comes up with an error:
    “No CUDA acceleration hardware detected”.
    When I plug my monitor back in, all is well.
    How do I reconfigure my displays so Resolve will work solely on my MBP display?
    Thank you in advance!
  • Dwaine Maggart
    February 16, 2012 at 7:25 pm
    In Mac Preferences, in Energy Saver:
    If you have an “Automatic Graphics Switching” selection, make sure it is NOT checked.
    If you have Graphics selections for “Better Battery Life” and “Higher Performance” make sure “Higher Performance” is selected.
    Dwaine Maggart
  • Andrew Hills
    February 16, 2012 at 7:41 pm
    Thanks so much!
