Activity Forums DaVinci Resolve Resolve media pool question.
  • Resolve media pool question.
    Posted by Pat Baril on November 24, 2011 at 3:04 am
    Hello, we will be using Resolve for grading a project that will be edit ( offline ) in Avid with DNXHD36 files coming from Prores 422 files. I did a small test exporting AAF to Resolve and I could reconnect to the original Prores files in Resolve ( I had only 3 clips for this test ). But in real life, I will probably end up with hundreds of Prores files in different folders.
    First, can I select a folder that contains sub folders ( one for each camera used ) and will Resolve be able to add to media pool all the clips in all subfolders?? If yes, how do I do it?
    Thank you !!
    Pat
    Sascha Haber replied 14 years, 10 months ago 2 Members · 1 Reply
  • Sascha Haber
    November 24, 2011 at 8:38 am
    Did you read the manual ?
    Please do so and use the search function here and in the PDF
    Works like a charm…
    “Add folders and subfolders to media pool”
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
