Activity Forums DaVinci Resolve resolve lut to avid
  • resolve lut to avid
    Posted by Len Hugh on June 21, 2016 at 8:06 am
    We are cutting in avid and want to try some different looks however the colour corrector in Avid is limited.
    I have been testing looks in resolve and then generating a 3d LUT which I can import into avid.
    This way we can experiment in the cut with a colour lut effect and not have to retranscode media.
    Its purely for offline edit work.
    The only problem is that the black and white points are not matching.
    I think its because the LUT coming from resolve is in a RGB space and my avid pictures are rec709. I have tested the path with some pluge and I think thats whats happening.
    Is there a way to compensate? I am a bit of a newbie to resolve.
    Thanks in advance.
    Glenn Sakatch replied 9 years, 10 months ago 2 Members · 1 Reply
  • Glenn Sakatch
    June 23, 2016 at 7:22 pm
    you could switch your avid project over to rgb and see if that helps
    Glenn
