Activity Forums DaVinci Resolve Resolve lite keeps crashing
  • Resolve lite keeps crashing
    Posted by Samir Kassab on July 28, 2011 at 3:39 pm
    Hi guys
    I’m switching from color to Resolve.installed the lite version for training..
    Resolve lite crashes whenever I try to load an XML or create a new project after displaying the progress bar for a couple of seconds.
    Help please!
    Mike Jenkins replied 14 years, 9 months ago 8 Members · 10 Replies
  • 10 Replies
  • Paul Jay
    July 28, 2011 at 5:04 pm
    If you want help then specify system specs.
  • Samir Kassab
    July 28, 2011 at 7:56 pm
    Sorry Jay,the specs should appear as my signature.
    MacBook Pro 17″
    NVIDIA GeForce GT 330M 512 MB
    2.66 GHz Intel Core i7
    4GB 1067 MHz DDR3
  • Peter Chamberlain
    July 29, 2011 at 1:24 am
    Hi, I expect that model MacBookPro will work with a low resolution image. Can you please contact
    davincihelp@blackmagic-design.com and let them know details of your problem via the log file. They can help you grab it.
    Peter
  • Rohit Gupta
    July 29, 2011 at 2:41 am
    Hi Samir,
    What OSX version are you using?
    If you are using OSX 10.6.8/10.7.0 (Lion), you will need to update CUDA to 4.0.19/4.0.21 from the NVIDIA website.
    If this doesn’t help please send us logs, and we will take a look. You can capture the logs using the following application:
    /Library/Application Support/Blackmagic Design/DaVinci Resolve/CaptureLogs.app
    Regards,
    Rohit
  • Samir Kassab
    July 29, 2011 at 8:42 am
    Thank you guys for your replies.
    I’m running on snow leopard 10.6.8
    I did contact DaVinci support they replied with a list of supported MBP.my laptop is supported, but its just 4 Gb not 8Gb.if that is the only problem , I can upgrade to 8Gb . But if it’s not , I don’t wanna spend anymore money on a dead end machine
    I will sending my logs soon
    Regards
    MacBook Pro 17″
    NVIDIA GeForce GT 330M 512 MB ,
    4GB 1067 MHz DDR3
  • Sascha Haber
    July 29, 2011 at 3:23 pm
    I would at least try a fresh install before giving up.
    Of OSX, not Resolve that is
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Samir Kassab
    July 29, 2011 at 4:58 pm
    Finally I got Resolve lite finally up and running , I don’t know what exactly fixed it’ but here is what I did :
    -Removed Resolve
    -Removed all blackmagic softwares
    – Verified and repaired disk permission
    -Set the performance to the maximum, disabled all of the energy saving options in the preferences
    – Re- installed Resolve
    -That’s it
    Now I can go through the manual page by page and learn all about this mythical piece of software
    Thanks to all of you guys
    MacBook Pro17″
    4GB 1067 MHz DDR3
  • Dan Moran
    July 30, 2011 at 4:42 pm
    Hi Samir,
    This step : “disabled all of the energy saving options in the preferences”
    Is what would have fixed it. Resolve needs to use the bigger graphics card for processing and when you disable the energy saving options it would enable the larger card full time.
    I’m glad its working and hope you enjoy it!
    D
    Dan Moran
    DaVinci Application Specialist
    Blackmagic Design EMEA
  • Clayton Lonie jr
    August 30, 2011 at 9:23 pm
    System: MacPro Quad Core
    Nvidia GT 120
    8gb Ram
    2 HP LP2275w monitors
    Upon launch I keep getting Critical Exception : BtException: Driver not loaded Driver not loaded…
    Any idea what’s happening…
    Also the Program Window spans my two monitors but only stretches on to the other monitor ..
    how can i get it to size correctly to just the one screen.
    Clayton Lonie
  • Mike Jenkins
    November 19, 2011 at 4:18 am
    I’m getting the same error. Any help would be appreciated. I’m on a Hackintosh so my problem might stem from that, but I’ll try any fixes suggested. I can post logs too.
