Activity › Forums › DaVinci Resolve › Resolve Lite – Is it possible to run on a portable PC?
  • Resolve Lite – Is it possible to run on a portable PC?
    Posted by Christopher Lowden on May 13, 2014 at 5:26 pm
    Hello
    I would like to start learning Davinci Lite and I want to buy a portable PC for this. Can anyone recommend a cheap PC config so that I can learn the basics? I can happily work in SD or compressed HD as I will not be using it for production.
    Many thanks
    Sascha Haber replied 12 years, 4 months ago 4 Members · 4 Replies
  • Margus Voll
    May 13, 2014 at 8:22 pm
    look at the GPU’s in laptops.
    I have seen one DOP around here has Lite running in he’s laptop.
    Not sure what model but basically you should find one.
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 10, OSX 10.8.5
    MacPro 5.1 2×2,93 24GB
    GUI 4000 / GPU GTX 780
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
  • Glenn Sakatch
    May 14, 2014 at 1:55 pm
    you need cuda acceleration for it to run. If you spec out a laptop, make sure of that. I have an HP Zseries laptop and it runs fine, but some of the models only have built in hp graphics, not nvidia, so beware. you also need 1920 x 1080 min. resolution. a 13 inch laptop won’t work. You may find it cheaper to build a desktop and put an nvidia card in it. Check the resolve specs on their website. (there are different specs for windows vs Mac)
    Glenn
  • Christopher Lowden
    May 14, 2014 at 5:36 pm
    Thank you both for the advice. I did not see anything on portable PCs on the BM site but if I only need a decent CUDA validated card and a 1920 screen, I have plenty of choice.
    Thanks again
  • Sascha Haber
    May 14, 2014 at 6:33 pm
    I would go for an external Display anytime.
    A slice of color…
    Resolve 10.1.4 – Smoke 2015
    Colorist / VFX / Aerial footage nerd
    https://vimeo.com/saschahaber
