Activity › Forums › DaVinci Resolve › Resolve Lite 8.1 _ Render ProRes 4444 fails… picture gets cut off.
Posted by Helge Tjelta on October 15, 2011 at 8:36 amHi, rendering to ProRes HQ (422), is OK. Changing to ProRes 4444, cuts of picture in the right side, almost 1/3 of picture gets cut of.
Any ideas why?
cheers helgeHelge
Dwaine Maggart replied 14 years, 6 months ago 4 Members · 7 Replies -
Rohit Gupta
October 17, 2011 at 9:28 amHi Helge,
We are unable to reproduce this issue. Could you please provide details of what hardware you are on? If possible, please grab logs, and send to your support email so we can check? (davincihelp at blackmagic-design.com)
Isaac Chung
March 9, 2012 at 4:04 pmHello Helge, did you ever figure out this problem? I’m having the exact same issue with Da Vinci Resolve 8.1
Dwaine Maggart
March 9, 2012 at 7:19 pmThis is related to using an ATI/AMD GPU card. This should be fixed in 8.1.1, or the new 8.2 release.
Dwaine Maggart
Blackmagic Design DaVinci Support -
Isaac Chung
March 9, 2012 at 7:20 pmI got it to work when I render out at 1 frame per second. Is this normal?
I’m actually using 8.1.1
Dwaine Maggart
March 9, 2012 at 8:09 pmIt would not be normal with 8.1.1, but what exactly was your problem? The right third of the image being cut off as in the original post? Or not rendering at all?
Are you using an AMD/ATI GPU card?
What resolution files are you rendering?
Dwaine Maggart
Isaac Chung
March 9, 2012 at 8:20 pmHi Dwaine, yes, it’s the same problem as the first person who posted – the right third of the image is cut off. I’m using Alexa files, prores 4444 log c (1920×1080), and when I render Prores 422, everything is fine, but prores 4444 and DPX both crop the image.
I definitely have 8.1.1
My GPU: AMD Radeon HD 6970M 2048 MB
Dwaine Maggart
March 9, 2012 at 8:39 pmIf you can, I would suggest trying 8.2 to see what happens.
You are apparently on an iMac or MacBook Pro?
Dwaine Maggart
