Resolve lite 10 cant get render in 29.97
Hi All,
Thank you in advance. I am struggling here. I can’t seem to get Resolve to render in 29.97Here’s the background
Project shot on the Canon60d in 29.97. transcoded to ProRes422HQ. cut in FCP 7. I exported the cut into XML v5.Now on my final try – before importing the XML to Resolve I created a new project changed the timeline and playback frame rates to 29.97.
Saved project. Quit Resolve.
Reopened Resolve.
Imported XML and let it create a timeline it said was at 29.97In deliver – my option for frame rate was greyed out – again at 29.97.
But no such delivery. Everything was oddly too long – with handles of varying sizes (between 2 and 7 frames added on either end) And I mean added – not just 29.97 stretched to 23.98 but frames that were not in the cut. More importantly – this was all exported at 23.98…
Cut them all back by hand to match and was sad to learn that this wasn’t uniform, usually a 5-7 frame head and a 2 to 3 frame tail.
Am I doing something wrong here? My sequence in Final Cut is at 29.97… I always as a rule just drag the desired clip into FCP to let it determine the correct frame rate and accept. In this case though I checked of course and yes.. 29.97 is the current format.
Any help would be so appreciated. It’s fixed now for this job but I have 2 more cut versions to deliver this week with the same settings.
thank you in advance!!
