Activity › Forums › DaVinci Resolve › Resolve is More Saturated than my outputs
Posted by William Edwards on March 18, 2012 at 9:50 pmI’ve noticed that when I view the source material on the viewer in Resolve, it is showing an image that is a great deal more saturated than what I end up outputting. Any suggestions?
Apple Pro Res to Apple Pro Res, via FCP XML.
Dimitrios Papagiannis replied 14 years, 5 months ago 5 Members · 9 Replies -
Juan Salvo
March 18, 2012 at 10:54 pmAny suggestions?
Yes. Don’t use a computer display to evaluate a video image. -
Ola Haldor voll
March 18, 2012 at 11:29 pmWhat Juan said.
Don’t rely on the computer monitor.Some times the client may say “I like what’s on the computer monitor better”. Fine. Make whatever is on the video monitor look like the computer monitor. But the image on the computer monitor will look “too much” then.
It just show’s the importance of working in a calibrated environment.
William Edwards
March 18, 2012 at 11:34 pmFair enough, for a broadcast environment. But when video is going to stay on the web, wouldn’t it be better to stay in the environment of a computer/web? If you have a color calibrated computer monitor, shouldn’t the viewer in Resolve produce the same outputs as you end up with your quicktimes? Or was it just not built for that?
Juan Salvo
March 18, 2012 at 11:47 pmEvery single individual computer monitor in the world looks different. Some a little some drastically. There is no predictable and standardized way of predicting the appearance of a consumer display. Video by comparison is rather standardized bt.709. Best thing is to grade Ina calibrated video monitor even if it’s for the web. Certainly don’t grade on the GUI. You can additionally calibrate your computer display using a probe and software to produce a monitor profile. You have a probe, correct?
William Edwards
March 18, 2012 at 11:56 pmThanks for responding Juan. Yes, I do have a probe. I recalibrated it, as there was a chain on this problem with i1Profiler and the new version they put out, and it seems be be working a lot nicer now. Question with this though, what gamma is broadcast set at? 2.2 right?
So I can eventually move away from this problem: I was looking at the Eizo monitor. I don’t know if there are others you can recommend. My favorite was the Panasonic Plasma, as it sees blacks very well.
William Edwards
March 19, 2012 at 12:11 amI think I figured it out, and this might all be elementary to you guys.
ProRes, H264, or other apple images playback in gamma 2.2. So Resolve and FCP, for example, would also play back the image in a 2.2 space. If I have the monitor calibrated at gamma 2.2 and not 1.8, resolve images would be saturated and weird because it’s a 2.2 gamma on a 2.2 image. Colorsync works with quicktime files to make it look the “proper” gamma, but it doesn’t work with Resolve to make this (again in quotes) “correction”.
Margus Voll
March 19, 2012 at 8:48 amI think Resolve shows you “more” colors than it fits to your output format.
When rendering out colors are reduced by the format of compression itself.
I see it all the time. After export stuff are more pale. Specially when you make some internet compatible files.
Margus
William Edwards
March 19, 2012 at 6:27 pmThanks Margus,
I agree, but also when I calibrated the GUI monitor to gamma 1.8, it was a lot closer than gamma 2.2.
March 29, 2012 at 5:32 amHow should we deal with this situation if it is encountered?
