Resolve easyDCP – strange behaviour while working with animation
Hello all,
Actually the thing I need the most is the confirmation that I am not wrong.
Yesterday I created 2K SCOPE DCP with easyDCP plugin for Resolve out of 2048×858 TIFF sq containing 2D animation (ca 30min if it’s important).
In a first try I set maximum bitrate to 160Mbps – the final j2c mxf was ~34Mbps according to MediaInfo.
In a second, I moved it to 250Mbps but bitrate of outputted file have not changed.I assume that as long as I am working with 2D animation there is no need to use standard DCI bitrates (150Mbps+), because it would only be generation of “empty bytes”?
On the other hand, I tried to do the same thing with dcp-o-matic, which uses OpenJPEG encoder and final bitrate was much higher (as desired)….
So I am a bit confused.
Probably the best way would be to watch both (easyDCP and dcp-o-matic) versions on the screen and compare quality, but I will not be able to do that in next few days.Thanks in advance for your feedback!\
best
Marek
