Activity Forums DaVinci Resolve Resolve crashing and running slow on new mid-high spec PC
  • Resolve crashing and running slow on new mid-high spec PC
    Posted by Josh Williams on October 11, 2021 at 10:54 am
    Hi guys,
    I just upgraded my PC as I am working more in resolve (mainly editing) and finding it is waay more intensive to run.
    I am getting frequent crashes, often my PC will be unresponsive for every 1 second out of 5 or similar which is obviously insanely annoying when working to tight deadlines.
    Mainly editing footage from FX6, FS7, Pocket 4k. Keeping my timelines to 1080 using stabilisation and some other effects but tbh I find I can have issues in projects without.
    PC specs
    Motherboard – MBP b550 gaming carbon wifi
    CPU – AMD Ryzen 9 3950X
    Boot – WD Blue SN550 250 GB NVME
    GPU: RTX 3070Ti
    Power supply: Strix 850W
    Running Resolve 17.1.1
    Any ideas would be really useful! thanks,
    Josh
    Glenn Sakatch replied 4 years, 11 months ago 4 Members · 3 Replies
  • Tom Watson
    October 11, 2021 at 2:40 pm
    A 250 GB HD is usually not large enough to handle the cache necessary for smooth operation. I had to install a 1 TB SSD just to use for cache, and then I need to delete unused cache frequently.
    There are many things, often associated with project setup, that can cause crashes, but when the cache fills the hard drive mine crashes every time.
  • Eric Santiago
    October 12, 2021 at 2:31 pm
    Most of the time it’s the media to blame.
    Unless you have a heavy node project.
  • Glenn Sakatch
    October 12, 2021 at 8:16 pm
    You’ve listed your boot drive, but not your main storage. What are you running footage off of?
    Are you using it for cache as well, or the boot drive? I agree with Tom…that boot drive is too small. Not just for resolve cache, but many windows temp files..can’t imagine its not already full.
