Activity Forums DaVinci Resolve Resolve Conf.
  • Resolve Conf.
    Posted by Nuno Garcia on February 6, 2011 at 3:18 pm
    Hello.
    i’ve been studying what is the best configuration possible, for my Resolve, most of the work is advertising which requires many effects, and same music clip.
    so if u be able to give me a precious review i I thank you in advance. all opinions are valid.
    Mac
    “Two-processor 6-core Intel Xeon” Westmere “at 2.66 GHz (12 cores) 12 GB (6 x 2 GB), 4 x Hard Disk Drive 7200 rpm Serial ATA 3 GB / s with 1 TB, ATI Radeon HD 5770 1 GB, One 18x SuperDrive
    DeckLinkHD 3D+
    GPU-Expander cubix 4 slot´s PCIe
    Nvidia FX400 x2
    and Monitor or PVM-L2300 sony, LM-2470 or Dolby PRM 4200.
    this is the wish list
    Tanks
    Nuno
    Margus Voll replied 15 years, 7 months ago 2 Members · 3 Replies
  • Margus Voll
    February 6, 2011 at 6:44 pm
    Hi.
    I work with advertising and use Resolve.
    I can not say what is the best workflow for you but i use a lot of different tools.
    I do not ever use just one tool. Different tools for different work.
    For color correction Resolve is my tool.
    I used color but it is too slow for my turnover.
    What i see is really stable system and great speed.
    Not only render speed but the speed you see your changes.
    For example like with 3d cgi. You can make really great result
    but if it takes you 4 times longer time then its is hard
    to justify time and cost for the client.
    I feel the same with Resolve. It takes me minimum 3 times less
    time to grade a spot which is usually only 30 seconds.
    You really have to think what is your goal here.
    Mine is speed and stability.
    Margus
    https://iconstudios.eu
  • Nuno Garcia
    February 6, 2011 at 10:12 pm
    Tanks Margus
    yes the point is that i need same fast, solid, machine.
    do you think this graphics boards do the job?
    because the resolve will be in the next room with his grandfather 2kplus.
    do you know how many nodes you can use these two fx4000? in hd or 2k.
    tanks
    Nuno
  • Margus Voll
    February 7, 2011 at 6:48 am
    Hi.
    I do not have exact number yet. BM guys probably could tell it to you exactly.
    Margus
