Activity Forums DaVinci Resolve Resolve Avid Codecs
  • Resolve Avid Codecs
    Posted by Dave Williams on July 26, 2011 at 9:31 pm
    Anyone out there have any experience with transcoding with Resolve’s Avid codecs then reopening in Avid Media Composer 5.5.up?
    These Pro res files are being transcoded in Resolve to MXF Dnx 36 8bit. Having a slight problem opening them in Media Composer but they will open fine if they are taken back into Resolve?
    Gopal Balaji replied 15 years, 1 month ago 6 Members · 12 Replies
  • 12 Replies
  • Illya Laney
    July 26, 2011 at 10:29 pm
    How are you trying to bring them in to Avid?
    twitter.com/illyalaney
    nextLAB Mobile
    SpeedGrade DI
    Resolve
    da Vinci 8:8:8 Renaissance
    Color
    Truelight
  • Marcin Zwolski
    July 27, 2011 at 9:07 am
    Did you put your graded files in
    Avid MediaFiles/MXF/1 folder?
    If so you should see them in Media Tool in AMC
    Cheers,
    M
  • Rohit Gupta
    July 27, 2011 at 9:13 am
    Hi Dave,
    Please make sure the reel number support in Resolve is enabled (in the config page), else Resolve renders here files with no reel/tape information, and Avid doesn’t like these MXF files.
    Regards,
    Rohit
  • Marcin Zwolski
    July 27, 2011 at 10:09 am
    Rohit,
    Could you elaborate?
    I’m having problems with relinking files from Resolve in AVID.
    The issue is AVID can reconnect basing on either ‘Tape Name’ or ‘Source’ from AMA sequences.
    Would it be possible to add ‘Tape name’ or ‘Source’ to Resolve import/export metadata?
    Cheers,
    M
  • Dave Williams
    July 27, 2011 at 1:17 pm
    Are you referencing under “Timeline Conform Options” the 1.Assist using reel numbers from the
    And which has been with your experience the best option to use.
    Either “Media folder name” or “Embedding in source clip name”?
    Thanks for all your help I am narrowing in on a solution.
  • Dave Williams
    July 27, 2011 at 1:19 pm
    I had not put them in the Avid folder 1 the first time. They were in their own folder because I was trying to keep the original file structure intact, but maybe that is the wrong way to look at this.
    Thanks again for the help.
  • Eric Santiago
    July 27, 2011 at 1:51 pm
    I too am looking for a way back whether it “linked” or not.
    Anything Ive rendered in Resolve 8 to MXF is not recognized by Avids file systems.
    has anyone managed to see an Resolve MXF in their bins?
  • Rohit Gupta
    July 27, 2011 at 1:56 pm
    Yes – you can use any of the options there depending on the source media. If you are using Red, you can use “Embedding in Source files”. For Red, this uses the filename of the R3D file without the _001 as the tape name.
    It is important to enable this before rendering, else Avid Media Tool won’t pick up the MXF file.
  • Marcin Zwolski
    July 27, 2011 at 2:11 pm
    You may create folder named “2” or “3” or “4” … and put your files there.
  • Eric Santiago
    July 27, 2011 at 2:38 pm
    Thanks Rohit, can you elaborate a little?
    If RED do you mean using RED clips in Resolve then at Render set that option? I thought Ive tried everything even adding that _001 to the rendered file and still Avid refuses.
    Ive posted this question on here and REDUser concerning Avid AAF Round tripping.
