Activity Forums DaVinci Resolve Resolve and third party OFX plugins render cache issue
  • Resolve and third party OFX plugins render cache issue
    Posted by Antoni Jones on October 14, 2021 at 9:49 am
    hello all,
    I’m fairly new to resolve so please forgive me if this has been asked and answered before.
    Whenever I apply a third party OFX effect to a clip in the timeline (in my case Boris FX Sapphire) the render cache does not work correctly. The thin red line that indicates if something is being cached either stays red or actually caches and turns blue but still plays at 4-5fps instead of the full 24fps my project is set at.
    Strangely, if I select the Color page and add an OFX effect to a color node it seems to cache correctly and play back at the full 24fps even when I then go back to the edit page. I can use it this way but then I have to go back and forth between the edit and color pages if I want to alter any of the effects settings which is not ideal. This does not happen to effects supplied by Blackmagic, they seem to work correctly.
    I have setup render cache correctly and am using the “User” preference so I’m not sure why this happening. Is this a know bug with third party plugins or am I missing something? Any help would be appreciated.
    Thanks.
    David Kaltenbach replied 4 years, 11 months ago 2 Members · 1 Reply
  • David Kaltenbach
    October 14, 2021 at 11:00 am
    I have often wondered the same. But in my case it does not render correctly when I use Fusion effects. I am considering adding Sapphire as a plug-in. You’ll get your answer soon. Thanks
