Activity › Forums › DaVinci Resolve › Resolve and new MacBook Pro Nvidea 650m
Posted by Christopher Adams on June 11, 2012 at 7:10 pmWith 2 thunderbolt ports I assume 1 for high speed raid array and the other or a bmd hdsi box. Could get interesting.
Thoughts?Matthew Sonnenfeld replied 14 years, 2 months ago 9 Members · 18 Replies -
Nate Weaver
June 11, 2012 at 7:23 pmYes, I’m curious how this 650M would do compared to a GTX285, which is the fastest I’m used to at this point?
I looked at the specs on the Nvidia site, and the 650M seems to have a higher clock and more cores, but bandwidth is less than a 285.
Possibly for 1080p video only (+GUI, of course), the bandwidth is enough?
Nate Weaver
Director/D.P., Los Angeles
https://www.nateweaver.net -
Juan Salvo
June 11, 2012 at 8:28 pmThe 650M should perform significantly faster than the 285. In theory. I would guess comparable to a gtx470.
Online Editor | Colorist | Post Super | VFX Artist | BD Author
Christopher Adams
June 11, 2012 at 9:14 pmThough if this is being used to work the display could this then not be used for cuda?
Juan Salvo
June 11, 2012 at 9:29 pmThere is an integrated gpu which can run GUI, freeing 650m for CUDA.
Robert Houllahan
June 11, 2012 at 9:36 pmI think that is auto switching like all of the Macbook-Pro’s and that you can use either the Intel 4000 GPU or the 650m but not both at the same time.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.comMAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma. Light-Space CMS + Hubble
Juan Salvo
June 11, 2012 at 9:51 pmTo display. This is the same as before with the last nvidia gpu on 17″. GUI on integrated. Processing on discreet.
Margus Voll
June 12, 2012 at 6:02 amone would use 5 ghz wireless instead of thunderbolt ?
Margus
DaVinci 8.2.1 OSX 10.7.3
MacPro 5.1 2×2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro -
Jimmy Christensen
June 12, 2012 at 6:47 amNot many companies allows for connecting to the internal network through WiFi (and with good reason).
Margus Voll
June 12, 2012 at 6:51 amyes but we can not say it is not possible in tech sense. have usb lan then.
different question is if osx supports it.
mostly you would see laptop as on the go machine
Margus
Multibridge 2 Pro
