Activity Forums DaVinci Resolve Resolve and Multicam from FCP7
  • Resolve and Multicam from FCP7
    Posted by Simon Blackledge on August 16, 2013 at 12:01 pm
    I take it there is a bug of some form currently ?
    98% of clips connect with no errors but are slipped and a few I get extent errors.
    Seems the frame count is taken from the start of the multi cam clip from tcp but some clips within the multicam dont actually start at the begining of the multicam clip
    ie
    multicam clip is 500 frames
    clip 1 is 450 frames
    clip 2 is 398 frames
    clip 3 is 500 frames
    Ended up rendering out flat edit and splicing using scene detect and loading an edl. not ideal!
    S
    John Sellars replied 13 years ago 3 Members · 2 Replies
  • Eric Johnson
    August 16, 2013 at 3:47 pm
    When dealing with MultiCam, you need to “Collapse MultiCam Edits”, right-click sequence to find option, and/or, use the Media Manager to strip the MultiCam relationships.
    In Media Manager, select “Use Existing” this will pretty much make an exact copy of your sequence. Uncheck everything related to handle and consolidation. At the bottom of the window there is a checkbox for “Include non-active MultiCam angles” uncheck. This will generate a new sequence rinsed of MultiCam in a new project. I tend to bring in the new Sequence into my working project, but that is strictly a matter of preference.
    Pretty sure you only need to do one, but both steps take next to no time, so I always feel safer doing both.
    Also, I’m not a 100% on this, but I believe this is a known issue for all NLE’s. I believe there is an exception in FCPX, but I’m not familiar with that particular workflow.
    eric b johnson
    online editor | colorist | workflow
    https://vimeo.com/39073239
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • John Sellars
    August 16, 2013 at 5:36 pm
    I have had problems even with media managed multicam projects. Use an EDL instead of the XML. You will lose sizing info, but if it’s only a few shots you can eyematch them using the still store (offline/mix). If you don’t have access to the FCP project this is the easiest way to get rolling. Just tell the editor to email you an EDL.
