Activity Forums DaVinci Resolve Resolve and multi channel audio
  • Resolve and multi channel audio
    Posted by Glenn Sakatch on January 31, 2014 at 9:52 pm
    Does anyone know if I can have resolve not assume that audio stems with 6 channels is not 5.1 surround sound audio?
    Doing RED with multichannel audio, and everytime I have a 6 track recording, Resolve wants to make it 5.1, which buggers up my Avid and Dailies outputs. I have to manually go in and tell the box that the audio files are mono, 6 channels, then after syncing to T/C on the video file, I have to tell it the Video file’s audio is mono 6 channel, and I have to assign each of the channels to the linked audio. Gets a bit tiresome after a while. I can’t see any audio input settings that would help me out.
    I get the same thing with 2 channel audio. It assumes Stereo instead of mono 2 track.
    I just need a “default audio” tab somewhere.
    Glenn
    Glenn
    Tomek Dyszkiewicz replied 10 years, 9 months ago 7 Members · 7 Replies
  • 7 Replies
  • Marc Wielage
    February 1, 2014 at 12:21 am
    What if you brought in the six tracks as a single polyphonic file?
    I’m still not of the opinion that Resolve is ideal as a delivery tool for multitrack audio projects.
  • Glenn Sakatch
    February 1, 2014 at 8:07 pm
    Hey Marc, the tracks do come in as a single, 6 channel file, problem is resolve is assuming its a 5.1 file instead of the poly file it is.
    Just doing dailies and transcodes right now, i still do my final delivery and ouputs through a different system. Resolve is great for this, except for its handling of the audio.
    Glenn
  • Leif Thomas
    May 6, 2014 at 12:52 pm
    I’m having the same problems right now. Do have found any solution for that problem.
    Also just rushes with multi audio tracks. Resolve 10.1.4. on a Mac.
  • Max Slomoff
    September 29, 2014 at 10:36 pm
    hi marc,
    may i ask what you recommend as the ideal tool?
    i’m looking to export dailies as multitrack quicktimes and i’m having trouble in both resolve and premiere 2014
  • Kamau Bilal
    September 2, 2015 at 6:35 am
    Was there ever a solution to this problem? Having this issue currently. Can’t find the work around…
  • Joana Reis
    October 7, 2015 at 9:14 pm
    I guess if you go into clip attributes/audio you are able to change it.
    hope it helps
  • Tomek Dyszkiewicz
    November 30, 2015 at 8:49 am
    Not sure if I got you correctly but try going to EDIT TAB, right click on audio track with your 6 channel audio and choose:
    Change track type to -> Adaptive -> 6
    Hope that helps.
