Activity Forums DaVinci Resolve Resolve 9b3 – Some files do not appear in Library
  • Resolve 9b3 – Some files do not appear in Library
    Posted by Joseph Mastantuono on September 1, 2012 at 12:41 am
    Finally getting to my first no pressure project to get Resolve 9 going, and I just created some Apple ProRes 422 outputs to use as Offline & some AIFF’s to use as chase audio for this project, and for some reason they will not appear in my library for me to add them.
    No wierd file names, no reason I can think of that they aren’t appearing…
    I tried 48khz AIFF files both 16 & 24 bit… no dice. Is there an issue with AIFF support so far???
    Strangely these .mov’s aren’t appearing either. I tried moving to another drive, just to see, and there definitely seems to be an issue with those files. But they’re working just fine in all other software (FCP, Premiere 6, etc..)
    Lots of other stuff is working just fine. I was able to bring in the project’s XML just fine. Just for some reason these files refuse to appear in the library. Any Ideas?
    Joseph Mastantuono
    http://www.goodpost.net
    Color Grading & Post Production Consulting
    Joseph Mastantuono replied 14 years ago 1 Member · 1 Reply
  • Joseph Mastantuono
    September 1, 2012 at 12:49 am
    I’ve solved the Apple Pro Res files, they were exported with “.mov” extensions…
    And I just converted the AIFF’s to WAV’s and they’re recognized.
    I’d love to know if there’s an issue with AIFF’s.
    Joseph Mastantuono
