Activity › Forums › DaVinci Resolve › Resolve 9.1- Missing Avid MXF Codecs in Deliver?
Posted by John Burkhart on January 19, 2013 at 10:01 amHi Guys,
We seem to have lost most of the Avid MXF codecs in “deliver” in 9.1. All the Avid codecs are 1:1 only, which takes up a hell of a lot of space. I’d like to use resolve to output proxies in dnxhd 36, or other codecs that were available in 9.0 and below.
Is this an oversight? Or were these codecs removed permanently?
John Burkhart
John Burkhart replied 13 years, 8 months ago 8 Members · 11 Replies -
Rohit Gupta
January 19, 2013 at 3:55 pmHi John,
This is a bug which affects the Lite version only, and on the Mac platform only.
We hope to have a fix available soon.
Regards,
Rohit -
Chris Kenny
January 19, 2013 at 8:35 pmNot seeing any DNxHD MXF options in Lite 9.1 on Windows 7 either.
Digital Workflow/Colorist, Nice Dissolve.You should follow me on Twitter here. Or read our blog.
Sascha Haber
January 19, 2013 at 9:22 pmI also like to see some options for SD.
UA slice of color…
Resolve 9.0.5 OSX 10.8.2
Colorist / Aerial footage producer
https://vimeo.com/saschahaber -
Andrew Stone
January 21, 2013 at 2:10 amI see all the DNxHD MXF codec settings on Windows 7 in Resolve 9.1
-Andrew
Chris Kenny
January 21, 2013 at 7:44 am[Andrew Stone] “I see all the DNxHD MXF codec settings on Windows 7 in Resolve 9.1”
Full, or lite? I generally test new versions on one of our dailies transcoding machines, which run lite, so I haven’t installed the full version of 9.1 yet.
Andrew Stone
January 21, 2013 at 3:59 pmThe lite version. 14 presets come up for DNxHD: 720p 8 bit to 1080p 444.
-Andrew
Chris Kenny
January 21, 2013 at 5:53 pm[Andrew Stone] “The lite version. 14 presets come up for DNxHD: 720p 8 bit to 1080p 444.”
Uninstalled, reinstalled, and now they show up. Weird.
Nodari Nozadze
January 22, 2013 at 9:36 amI tried reinstalling but DNxHD 36 deliver option is still not there, is there a workaround, I was looking for 9.0 version but can’t find it anywhere, does blackmagic give us an option to download an older version of resolve lite? maybe this problem won’t be an issue in an older versions.
Ted Weinbaum
January 22, 2013 at 9:59 pmRohit, I’m on a mac using resolve 9.1, and I find I can’t even link up with any MXF media so as to load an aaf, or get the media to the media pool. When I open the folder within Resolve, it appears empty instead of seeing the MXF36 files that are stored there (which wasn’t a problem with 8). Is this also part of the bug you mentioned for which a fix is being made?
Ted -
Jake Blackstone
January 23, 2013 at 2:36 amFor some reason BM keeps old versions of Resolve under “Drivers” software. It’s been this way forever. Can’t you guys at some point take care of it?
