Activity Forums DaVinci Resolve Resolve 9.0.3 and 200% Respeeds
  • Resolve 9.0.3 and 200% Respeeds
    Posted by Ben Mills on April 5, 2013 at 8:43 am
    I’m having a bizarre issue with 200% respeeds when conforming in Resolve 9.0.3
    All material was shot at TRUE 24. So naturally if you apply a 200% respeed you expect it to skip every other frame.
    01, 03, 05, 07, 09, 11 etc
    For some strange reason Resolve seems to follow this pattern to a point (that point isn’t the same all the time)
    So for example it will go
    01, 03, 06, 08, 10, 12.
    Any ideas as to why it may make this jump??
    Many Thanks
    Ben Mills replied 13 years, 4 months ago 4 Members · 5 Replies
  • Rohit Gupta
    April 5, 2013 at 11:45 am
    Check if you also have a mixed FPS case – project and media.
  • Ben Mills
    April 5, 2013 at 1:58 pm
    Everything is at 24fps timecode. Some material was shot at 48fps but with 24fps timecode. So even a 200% respeed on the 48fps material would bring it back to looking like 24fps. And the TC would still skip every other frame.
    I’ve got a work around for now but its way more manual than it should be for something so basic.
  • Sascha Haber
    April 5, 2013 at 7:00 pm
    And why are you on that old build again ?
    A slice of color…
    Resolve 9.1.1 OSX 10.8.2
    Colorist / Aerial footage producer
    https://vimeo.com/saschahaber
  • Michaelmaier
    April 6, 2013 at 8:13 am
    Maybe because he had problems with the new build like I did. I had to go back to 9.0.4 because the new build was crashing my system at start up and I couldn’t figure why. I lost my patience and went back to 9.0.4 since it worked fine and I missed no feature from the newer one. So I’m still at 9.0.4 at the moment and happy. Haven’t tried the very latest (9.1.3) yet though.
  • Ben Mills
    April 6, 2013 at 8:50 am
    I’m not too keen on upgrading to a different build right in the middle of conforming so thats sort of out of the question, wasnt sure if it was a weird bug people had come across when conforming from an avid sequence?
    Best
    Ben
