Activity Forums DaVinci Resolve Resolve 9: No option to link Chase audio anymore?
  • Resolve 9: No option to link Chase audio anymore?
    Posted by Peter Berg on September 8, 2012 at 3:25 am
    Hi all,
    So I just upgraded from resolve 9 Beta 3 to the Resolve 9 release version.
    At first I was getting choppy audio, but after restarting the appliation again, that seems to be ok.
    Having a different problem. In the user manual it says in order to link a timeline to a chase audio file, you should load the audio file in the source window, and then right click on the timeline and choose ‘Link Audio Chase Track’. When I do that, that option is not there.
    In the link area I only have, ‘Link Offline Video’, ‘Link With Audio From Selected Bin’ and ‘Chase Audio Settings’. Is this a bug? In the beta I was able to link to chase audio files without any problems.
    Anyone else missing the ‘Link Audio Chase Track’ option?
    Another problem in the Conform tab. I am not getting a video on my computer monitor in the source and record windows. I can see the video in the timline going out to my broadcast monitor (Through the Ultrastudio SDI) but it’s not showing up in my conform tab source/record windows. Anybody seeing this?
    I am on Windows 7, and running Resolve Lite.
    What am I missing?
    Thanks so much,
    Peter
    Jordan Mena replied 13 years, 6 months ago 6 Members · 11 Replies
  • 11 Replies
  • Teo Rižnar
    September 8, 2012 at 6:50 am
    I am having the same issue in conform page. It works fine for 2 min than image just disappear, also in offline/wipe mode. but on HDSDI output image is there.
    Color grade reel: https://vimeo.com/15480583
    Cofounder of https://nuframe.si postproduction
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Anish Prithviraj
    September 9, 2012 at 3:58 am
    Peter,
    After setting your chase audio settings, right click on the WAV/audio file in your media pool. There is an option to use the file as chase audio (I think it’s the last option).
    Anish
  • Sascha Haber
    September 9, 2012 at 9:38 am
    While we are at this, is the option to visually sync the audio file gone ?
    I seldomly get audio tracks that align perfectly fine, so moving them was quite important for me.
    A slice of color…
    DaVinci 9b3 OSX 10.8
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    Colorist / Aerial footage nerd
    https://vimeo.com/saschahaber
  • Anish Prithviraj
    September 10, 2012 at 10:07 am
    Sascha,
    I think you are referring to manual source wav file sync with a clip in the timeline? This can be done by opening a wave file in the source viewer, going to the corresponding spot on your timeline and then right clicking in your timeline and selecting “Link Source Viewer Audio with Video”.
    Any adjustments can be made by right clicking on the small icon on the bottom left of the clip in the video track and selecting edit. Alternatively you can slip audio by single frame increments as listed under the edit menu (Alt+. and Alt+,).
    Hope this helps.
    Anish
  • Sascha Haber
    September 10, 2012 at 12:44 pm
    Well, what I was looking for was the old style v8 where I just could open the audio viewer in the color page and manually slip it.
    I havnt found a replacement for that yet.
    A slice of color…
    RAID0 8TB
    Extreme 3D+
  • Peter Berg
    September 10, 2012 at 5:24 pm
    Hello Anish,
    Thank you for the email. I see that command now when I right click on the audio file. That has been changed from the way it worked in 9 Beta 3. So that was a bit confusing.
    Also the manual is now incorrect. It still describes it the way it worked in the Beta. Can that be fixed so it matches how the software now works?
    Also I am finding that when I first link the offline video track and audio chase track, the system does not play them back smoothly. But if I restart Resolve, it seems to fix itself.
    Strange.
    -Peter
  • Sascha Haber
    September 14, 2012 at 10:43 am
    I am totally confused too.
    So what ARE the steps now to sync a new audio file to a whole timeline ?
    I cant get it to work, only to the first clip.
    I also need to move it as sound people tend to change their in points every time.
    Any quick solution ?
    I am in a little panic here right now.
    A slice of color…
    RAID0 8TB
    Extreme 3D+
  • Sascha Haber
    September 14, 2012 at 11:52 am
    All right…i figured it out now.
    But I really really think this needs some love.
    I wish I had the audio just as a track, like in Avid or Premier or like it was in the old Resolve.
    I need to see the waveform under my video and want to grab it to move it around.
    No one adjusts offsets in seconds.
    Frames and subframes would be a good starting point.
    This whole Link chase track from bin….nah…
    Let us just grab the audio file and drag it down to the timeline.
    If it hits an empty area it counts for the whole timeline.
    If it hits a clip, it overrules the timeline audio.
    Done…simple and effective.
    A slice of color…
    RAID0 8TB
    Extreme 3D+
  • Peter Berg
    October 9, 2012 at 6:03 am
    I totally agree with Sascha here.
    The new method for linking up reference audio tracks just stinks (in my opinion). The version 8 method wasn’t perfect but it easier and more accurate in my opinion than version 9.
    Like Sascha said, I need to see the waveform in the timeline. Either in the color page or the conform page. It used to be the color page and I can see how that wasn’t the best place. So in the conform page then. We can see the waveforms of the clip source audio, but not the reference audio?
    Seems like Resolve is setup now for doing dailies and not for full final show grading. We use audio reference files on almost every job. And I find the way to sync them up now to be cumbersome. Also I need to adjust it frame by frame with timeline waveform display. So I can sync up to a cut point for example.
    Can this please be improved. It’s really painful and it feels like a step backwards.
    thank you,
    Peter Berg
  • Navin Singh
    November 19, 2012 at 7:12 am
    Hi
    help me out as m using resolve 9.
    but m not able to play audio with my current time line.
    Plz forward me the procedure to import,link and to play the timeline with audio.
    Plz its on urgent basis.
    Regards
    Navin
