Activity › Forums › DaVinci Resolve › resolve 9. how to disable video output?
  • resolve 9. how to disable video output?
    Posted by Blase Theodore on August 1, 2012 at 3:41 pm
    I frequently use resolve with other applications that use the decklink card. While other apps release the card when they’re done, Resolve holds onto it at all times. In v8, I solved this by switching to deck mode.
    Anyone figured out a v9 equivalent of a quick release for the decklink card? (Other than disabling it in preferences?)
    Blase
    Boris Tivchev replied 14 years, 1 month ago 3 Members · 3 Replies
  • Alexis Hurkman
    August 1, 2012 at 11:03 pm
    Disabling your video card in the preferences is the current official way to do this. The team had me put the following note in the manual:
    “Note: Disabling video output can improve real time performance when external monitoring and output is not a priority. You can also choose “None” when you’re using Resolve with another application open at the same time that’s using your workstation’s video output interface. When you’ve quit the other application, you can reselect the video output interface for use by Resolve.”
    http://www.alexisvanhurkman.com | http://www.correctionforcolor.com
  • Blase Theodore
    August 1, 2012 at 11:09 pm
    Yeah I saw that in the manual. But thats a bit more cumbersome than the previous solution. Perhaps a keyboard shortcut to that pref?
  • Boris Tivchev
    August 8, 2012 at 10:18 am
    What i find to work just as well is going to file/capture. It doesn’t work in Color or Delivery.
