Activity Forums DaVinci Resolve Resolve 9 Directory issues
  • Resolve 9 Directory issues
    Posted by Michael Holmes on August 12, 2012 at 4:23 am
    I am getting the following error messages and I can’t figure out how to eliminate them.
    (1) When I go to the Conform page, I get:
    “Failed to create directory
    ‘/Volume/CacheClip/audio/Volumes/Video1/Final Cut Events/Test of FS100/Original Media/’. ”
    (2) When I try to save a color grade to Memory A, I get:
    ‘/Volumes/.gallery/ae/9f’.
    Please check the file system permissions.”
    Based on these problems, I figured the parent directory is somehow not right (although it seems to be working fine). So I highlighted the clips, selected “change parent directory”, and I found that it is set to “/Volumes/Video 1”, which only links down to the partition “Video 1″. So, I changed it to:
    /Volumes/Video 1/Final Cut Events/Test of FS100/Original Media”
    which is where the original clips actually reside. Then the clips went blank (after a little time).
    So I changed the parent directory back to /Volumes/Video 1, and the clips reappeared.
    So, I will add a 3rd directory issue: I obviously don’t understand directories. 🙂
    What do I need to do resolve these directory issues?
    (FYI, the media clips were linked to Resolve 9 via XML round trip with FCP X).
    Toby Risk replied 14 years ago 3 Members · 2 Replies
  • Daniel Mcdonald
    September 18, 2012 at 2:20 pm
    I’ve been getting the same problem for quite some time. Since Davinci Resolve 9 Lite came out, I’ve been using it to make small proxy files of big AppleProRes4444 Log C clips, but the program crashes after rendering about 10 or so clips and I get this message:
    “Failed to create directory ‘/Users/ryankahm/Desktop/Video
    Folders to
    Archive/CacheClip/audio/VolumesBParchive3/MASTER FOOTAGE/A CAM/Reel_249/A249R1U3”
    I haven’t seen much documentation on this issue, at least something with a pragmatic answer. Anyone know how to fix it?
  • Toby Risk
    September 21, 2012 at 8:01 am
    Hi
    I had this problem.
    On my system for some reason Resolve 9 had reverted to a very old cache setting referencing a volume that no longer resides on my system. Despite Resolve 8 having worked ok with cache files on my current volume.
    I changed it in the Preferences | General Options Cache Files and Cache Stills setting
    Now I’m happy.
    Toby
    Colourist | Editor | Post-Production Consultant — 23 years at the post-production coalface, and still loving it.
