Activity Forums DaVinci Resolve Resolve 8.2 on a retina – 2nd monitoring out/cuda issues
  • Resolve 8.2 on a retina – 2nd monitoring out/cuda issues
    Posted by Jeff Brown on August 24, 2012 at 4:18 pm
    Hi all
    Running a 15″ Retina with a Magma (Rocket + esata) enclosure.
    Resolve is saying the Nvidia 650M is not supported. I’m on latest CUDA 5.
    Also can’t figure how to get a 2nd monitor (24″ dreamcolor) out over HDMI – (Works fine doing that in Scratch)
    Any help appreciated!
    Jeff Brown
    Jeff Brown replied 14 years ago 2 Members · 2 Replies
  • Dwaine Maggart
    August 24, 2012 at 9:48 pm
    Look in the Energy Saver section of Mac System Preferences, and uncheck the Automatic Graphics Switching mode.
    Resolve has limited support for dual GUI displays. All you can put on a second GUI display are the WFM scopes.
    If you are wanting the second display for grading, you will need to use a BMD UltraStudio 3D or Intensity Extreme box connected via Thundebolt. And then select that device in the Resolve Preferences window in the Video I/O area.
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Jeff Brown
    August 28, 2012 at 9:41 am
    Thanks Dwaine
    Got it working now. Threw a blackmagic extreme in the Magma and all works fine.
    Cheers
    Jeff
