Activity Forums DaVinci Resolve Resolve 8 Power Window is almost invisible
  • Resolve 8 Power Window is almost invisible
    Posted by Eric Williamson on July 23, 2011 at 12:41 am
    Hi.
    Long time reader and first time posting.
    I just got my resolve 8 studio up and running and the only issue I am having is with my power windows. Sometimes, when I create a power window, it looks fine and is bright yellow and clearly visible on my screen. Other times, when I create a power window, it comes up as barely visible, as if it were thinner and clear. Is there a setting I am missing or is this just a glitch in the system? Thanks.
    Eric
    Eric Williamson replied 15 years, 1 month ago 5 Members · 6 Replies
  • Thibaut Petillon
    July 23, 2011 at 7:41 am
    Just press the power window button (ie CPW if it is a circular power window) if you are on the da vinci panel, or click again on the shape in your UI you should have it back to normal.
    Thibaut
    freelance colorist – based in Paris, FRANCE
    https://vimeo.com/22733471
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Esteban Aguilera
    July 23, 2011 at 3:42 pm
    press ctrl-C this activate and deactivate the colored lines.
  • Rohit Gupta
    July 23, 2011 at 3:53 pm
    Can you check if your Play Still is turned off, and you are not in Wipe-A mode?
  • Eric Santiago
    July 25, 2011 at 6:01 pm
    Isnt it Command + C not Control?
  • Eric Williamson
    July 25, 2011 at 7:51 pm
    It was in Wipe A Mode. Tanks for that. Is there any way to not have it look that way in Wipe A mode or does it do that due to the alpha wipe?
  • Eric Williamson
    July 28, 2011 at 10:12 pm
    nevermind. key stroke command+w turns the wipe mode on and off. thanks for all the help everyone.
