Activity Forums DaVinci Resolve Resolve 8 dual Quadro 4000 Mac Pro
  • Resolve 8 dual Quadro 4000 Mac Pro
    Posted by Cris Baltazar on August 16, 2011 at 1:02 am
    Hi anyone knows if dual Quadro 4000 for mac can work. I’ve been trying to install these quadro’s but with no luck, a lot of kernel panics.
    Mac Pro 2009 8-core
    MacOSX 10.6.8
    2 Quadro 4000
    Cuda 4.0.19
    GPU driver 1.6.37.0 (256.03.25f01
    Margus Voll replied 15 years ago 6 Members · 10 Replies
  • 10 Replies
  • Kris Anderson
    August 16, 2011 at 1:19 am
    Double check you were supplied with Mac cards. They should have a MAC sticker on them. My vendor didn’t… so I know have two PC versions sitting here doing nothing as he won’t take them back.
  • Cris Baltazar
    August 16, 2011 at 1:52 am
    i have mac stickers on the quadro 4000
  • Margus Voll
    August 16, 2011 at 5:43 am
    in theory they should work nicely.
    do you use one as gpu and the other as gui ?
    i would put 120 in slot 3 for gui. just an idea.
    Margus
    https://iconstudios.eu
  • Cris Baltazar
    August 16, 2011 at 12:43 pm
    yes one is in slot 1 and the other in slot 2…
    its giving me kernel panics
    panic(cpu 8 caller 0x9d58dd): NVRM[1/6:0:0]: Read Error 0x0061002c: CFG 0x06dd10de 0x00180000 0x00000000, BAR0 0x9c000000 0xa5f80000 0x0c0e80a3, D0, P0/3
    Backtrace (CPU 8), Frame : Return Address (4 potential args on stack)
    0x94f6bcb8 : 0x21b837 (0x5dd7fc 0x94f6bcec 0x223ce1 0x0)
    0x94f6bd08 : 0x9d58dd (0xbec0dc 0xc5d7a0 0xbfb6e8 0x1)
    0x94f6bda8 : 0xaf14f0 (0x1846d804 0x19938004 0x61002c 0x1e09ab1)
    0x94f6bdf8 : 0x1ce0fe6 (0x19938004 0x61002c 0x6400 0xaeb1fb)
    0x94f6be18 : 0xab5338 (0x19938004 0x19a8d804 0x3800 0x1993d818)
    0x94f6be38 : 0xb5fa22 (0x19938004 0x19a8d804 0x3 0x0)
    0x94f6bea8 : 0x9c60ab (0x19938004 0x0 0x0 0x0)
    0x94f6bf48 : 0x97614b (0x19938004 0x17b4d01c 0x94f6bf68 0x1)
    0x94f6bf78 : 0x230235 (0x18539800 0x19938004 0x94f6bfc8 0x552f8c)
    0x94f6bfc8 : 0x2a179c (0x863ea0 0x0 0x10 0x0)
    Kernel Extensions in backtrace (with dependencies):
    com.apple.nvidia.nvGF100hal(6.3.7)@0x1c32000->0x21e7fff
    dependency: com.apple.NVDAResman(6.3.7)@0x96e000
    dependency: com.apple.iokit.IOPCIFamily(2.6.5)@0x928000
    com.apple.NVDAResman(6.3.7)@0x96e000->0xc5efff
    dependency: com.apple.iokit.IONDRVSupport(2.2)@0x961000
    dependency: com.apple.iokit.IOGraphicsFamily(2.2)@0x93f000
  • Dwaine Maggart
    August 16, 2011 at 5:12 pm
    The current correct Nvidia driver for those in 10.6.8 is: 256.02.25f01. That does not match what you say you are using, so that could be an issue. Also make sure you have the Aux power connectors connected to both cards. I’ve gotten a lot of calls from people who don’t hook up the Aux power connectors when they install a Q4000.
    Do you see the cards in the System Profiler properly?
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Eric Santiago
    August 17, 2011 at 2:53 am
    I had the Quadro 4000 a little early (vendor told me that Nvidia had driver problems) so I was SOL for a few weeks. Even after a fix it was good for awhile then OS X updated and killed the working drivers.
    Sorry its been so long since but you have to find the right drivers that matches the OS.
  • Cris Baltazar
    August 17, 2011 at 4:09 am
    its working on a single Quadro 4000 but whenever I put the second one on Slot 2 thats when I start getting kernel panics. It just go the the screen with out the apple logo
    “TLB invalidation IPI timeout: ” “CPU(s) failed to respond to interrupts, unresponsive CPU
  • Chris Tomberlin
    August 17, 2011 at 1:20 pm
    I was having similar problems with a single Quadro 4000. Kernel panics and other assorted flakiness. Correct drivers didn’t fix it. I ultimately did an RMA through my vendor and got another card. No problems since then. Apparently rare, but bad cards do happen. If you have one that’s working and one that’s not, it sure points in the direction of a suspect card.
    Chris Tomberlin
    Editor/Compositor/Owner
    OutPost Pictures
  • Cris Baltazar
    August 24, 2011 at 11:58 pm
    I finally got a replacement. But now the Davinci is recognizing only 1 GPU. I see 2 NVIDIA Quadro 4000 in my Mac’s System Profile.
  • Margus Voll
    August 25, 2011 at 7:16 am
    if you have only 2 gpus in the machine then it is normal. Resolve uses on for processing and the other for ui. I have not tested it but if you had 120 + 2x 4000 then there could be option to have power of two 4000 units.
    Margus
