Activity › Forums › DaVinci Resolve › Resolve 8 – are there still some CUDA only elements?
  • Resolve 8 – are there still some CUDA only elements?
    Posted by Clayton Burkhart on June 20, 2011 at 7:10 am
    As per a discussion over in the Apple Color room, what aspects of the new Resolve 8 are still CUDA only, even though this app now runs on OpenCL?
    Peter Chamberlain replied 15 years, 3 months ago 3 Members · 2 Replies
  • Margus Voll
    June 20, 2011 at 7:38 am
    On CL you have some limitations as you know up HD rez and noise reduction runs on CUDA.
    SO if you will want to have maximum off your system you will get cuda gpu’s.
    If i’m not mistaken then CL only supports one gpu as CUDA can run 4 or more.
    Hot this gives you some info.
    Margus
    https://iconstudios.eu
  • Peter Chamberlain
    June 20, 2011 at 8:22 am
    We are recommending the OpenCL implementation for only up to HD res and currently its only available on a single GPU. Noise Reduction is only possible on the CUDA GPUs due to the high processing demands required for NR.
    On the Mac OS X up to three CUDA GPUs can be used for image processing, another GPU for the UI, and on the Linux OS we support up to 16GPUs.
    Peter
