Activity Forums DaVinci Resolve Resolve 7.1.2 won’t start
  • Resolve 7.1.2 won’t start
    Posted by Andrew Shtern on June 14, 2011 at 8:32 am
    Sometimes Resolve just refuses to start. Usually it happens after several start-grading-quit sessions.
    The last line on the splash screen is “Checking Licenses”, and then it quits. And doesn’t work until reboot.
    Console says:
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] ActCCMessage Already in Table: Code= c005, Mode= 12, Level= 1, CmdKey= -1, Option= 0
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] ActCCMessage Already in Table: Code= c006, Mode= 12, Level= 1, CmdKey= -1, Option= 0
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] ActCCMessage Already in Table: Code= c007, Mode= 12, Level= 1, CmdKey= -1, Option= 0
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] ActCCMessage Already in Table: Code= 214, Mode= 0, Level= 0, CmdKey= -1, Option= 0
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] 7.1.2 (#029)
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] Main thread starts: A002C540
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] [0xa002c540] | Undefined | INFO | 2011-06-14 11:29:14,149 | --------------------------------------------------------------------------------
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] [0xa002c540] | Undefined | INFO | 2011-06-14 11:29:14,150 | Loaded log config from /Library/Preferences/Blackmagic Design/DaVinci Resolve/log-conf.xml
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] [0xa002c540] | Undefined | INFO | 2011-06-14 11:29:14,150 | --------------------------------------------------------------------------------
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] [0xa002c540] | DbCommon2 | INFO | 2011-06-14 11:29:14,451 | Loading dblist file: /Library/Preferences/Blackmagic Design/DaVinci Resolve/dblist.conf
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] [0xa002c540] | DbCommon2 | INFO | 2011-06-14 11:29:14,475 | Database [Local_DB] current version <7.1.0.29> updated on <2010-12-23T14:38:54>, remark:
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] [0xa002c540] | DbCommon2 | INFO | 2011-06-14 11:29:14,481 | Connect to database Local_DB driver 0x5377e20
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] [0xa002c540] | UI | INFO | 2011-06-14 11:29:14,482 | Succeed to load style sheet ::/Stylesheet/Application
    14.06.11 11:29:14 [0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046] [0xa002c540] | Main | INFO | 2011-06-14 11:29:14,483 | Finished loading Application style sheet
    14.06.11 11:29:14 Resolve[62046] loader loading...
    14.06.11 11:29:16 com.apple.launchd.peruser.501[471] ([0x0-0xcc7cc7].com.blackmagic-design.davinci.Resolve[62046]) Exited with exit code: 1
    Is anybody has the same problem or solution?
    Andrew Shtern
    Editor/Colorist
    The Coffeepost @Kiev, UA
    Andrew Shtern replied 15 years, 2 months ago 4 Members · 5 Replies
  • Joseph Mastantuono
    June 14, 2011 at 12:03 pm
    I’ve encountered this, I find that it sometimes happens if I boot the system with the dongle plugged in. I unplug the dongle, boot, and then plug it in, post boot.
    Joseph Mastantuono
    Online Editor – Colorist – Post Consultant
    Brooklyn based finishing at reasonable prices
    917.969.1583
  • Andrew Shtern
    June 14, 2011 at 1:18 pm
    Hmmm, for me it never happens on the fresh booted system, only after several hours of work. Mostly when i work in Resolve, then close it and work in FCP, then Resolve again. I’ve tried to replug the dongle, but this doesn’t help. Only reboot or relogin.
    Andrew Shtern
    Editor/Colorist
  • Bastiaan Houtkooper nsc
    June 14, 2011 at 3:16 pm
    Do you have the dongle plugged straight into the machine or via a USB hub? Had some troubles with that before…
    Resolve system:
    MacPro 8 core 2010 – 16B memory
    9TB harddisk (1 system disk, 8TB in software raid 0 for data)
    Nvidea GTX285
    Nvidea GT120
    Blackmagic SDI Decklink
    RedRocketcard.
    Tangent Wave panel
    Transvideo 15″ Cinemontor Evolution
    Also running it on a MacBook Pro 17″ (5.2)
    160gb SSD and 750gb HD
    8gb mem
  • Brandon Thomas
    June 14, 2011 at 3:52 pm
    I’ve run into this issue. I think it’s being caused by FCP controlling the decklink. If i quit FCP, I can start Resolve again fine.
  • Andrew Shtern
    June 14, 2011 at 4:24 pm
    [Bastiaan Houtkooper NSC] “Do you have the dongle plugged straight into the machine or via a USB hub? Had some troubles with that before…”
    Bastiaan, the dongle plugged directly into one of the USB ports (on the back side of Mac)
    [Brandon Thomas] “I’ve run into this issue. I think it’s being caused by FCP controlling the decklink. If i quit FCP, I can start Resolve again fine.”
    Brandon, no, the FCP is closed when i’m trying to start Resolve.
    Generally the problem just happens time to time.
    Sometimes i can run Resolve and FCP simultaneously (with FCP Video Out turned off), sometimes i just can’t start Resolve alone.
    Andrew Shtern
    Editor/Colorist
