Activity Forums DaVinci Resolve Resolve 16.2 removes Node Numbers in the Node Graph making Keyframing an absolute pain
  • Resolve 16.2 removes Node Numbers in the Node Graph making Keyframing an absolute pain
    Posted by Drew Tekulve on April 16, 2020 at 6:21 pm
    Perhaps there is a setting I’m missing, but ever since I updated to Resolve 16.2 (and quite possibly even before this version), I lost the ability to see the node number in my node graph. They have all been replaced by ellipses that don’t indicate what corrector number it is. Normally this shouldn’t be an issue, but trying to figure out what corrector to select on my keyframe panel is impossible. Even trying to select the node on the Advanced pPanel numpad is impossible. I will often add correctors to my base primary corrections after the fact to tweak things, ostensibly changing the node order but I have no way of knowing.
    Is there a setting somewhere that switched when updating?
    Drew Tekulve replied 6 years, 5 months ago 2 Members · 2 Replies
  • Dmitry Kitsov
    April 16, 2020 at 10:29 pm
    Hello, Drew,
    What happens if you adjust the zoom of the node tree using the slider? I see you have zoomed all the way out.
    Can you see the node labels at a different zoom level?
    Dmitry Kitsov,
    Blackmagic Design technical support agent
  • Drew Tekulve
    April 16, 2020 at 10:55 pm
    Privyet Dmitry,
    Yeah I tried zooming in and out on the node graph and it still shows only the ellipses.
