Activity › Forums › Blackmagic Design › Resolve 11 AAF to Avid Error
  • Resolve 11 AAF to Avid Error
    Posted by Shane Ross on June 14, 2015 at 6:44 am
    Hey all. I’ve sent a small test sequence from Avid to Resolve 11, to check out the workflow. The footage is from a C300, I transcoded it to DNx175, then exported an AAF, imported to Resolve, and did a cursory grade. I then rendered out the footage, put it into the Avid file structure, and then exported an AAF out of Resolve.
    I can import that fine into Avid…but when I open the sequence, all the media is offline, and I’m hit with two errors:
    and
    And then I get debugger error, and then an EXCEPTION…and crash.
    Anyone help me with this one…am I doing a step wrong? If I load the .mdb into a bin, all the footage comes in fine.
    Shane
    Little Frog Post
    Shane Ross replied 11 years, 3 months ago 1 Member · 1 Reply
