Activity › Forums › DaVinci Resolve › Resolve 10b2 color and export questions
  • Resolve 10b2 color and export questions
    Posted by Eric Chase on October 1, 2013 at 12:37 am
    (Apologies if this has been asked before in DR10b1)
    1) Resolve used to remember all the grades from a particular clip. As you graded 1 clip, the other edits form that clip would also get graded. BR10B2 default each grade separately.
    2) Related to Q1: Master grade doesn’t appear to work. If I duplicate a timeline, or import the same XML again, the grades are not there.
    3) After I render for FCP7 export, sometimes the edits are short 1 frame. (1080p/23.976fps)
    4) After I render for FCP7 export, opacity fades come up as 0% for the whole clip.
    5) slow motion doesn’t work. Wrong timecode is affected.
    Thanks for your time.
    John Tissavary replied 13 years ago 2 Members · 1 Reply
  • John Tissavary
    October 2, 2013 at 10:56 pm
    Page 167 of the DaVinci Resolve V10 manual tells you everything you need to know to get master timelines in your vl0 project.
    John
    John Tissavary | colorist | owner
    The Post Collective
