Activity Forums Apple Final Cut Pro Legacy Resolutions – Update – Still need help
  • Resolutions – Update – Still need help
    Posted by Jennifer Arani on February 27, 2009 at 10:46 pm
    Hello,
    Okay so here is the update
    Export from camtasia
    Resolution=1024X768
    File Type – QuickTime
    Codec – Animation
    Frame Rate – 29.97
    Quality – 100%
    Size 1024X768
    FCP
    Sequence Settings
    Frame Size 1024X768 Custom (4:3)
    Field Cominance:Lower(even)
    QuickTime Video Settings
    Compressor-Animation
    Quality – 100%
    When I export/quicktimemovie(with make movie contained checkmarked) it looks WONDERFUL if you open this QT movie and play it.
    BUT….
    I can’t make a DVD with this. I have tried and it is a hot mess when played back.
    Dennis – I tried your steps to the tee and the computer shots become pixelated –
    Some how some way going from the 1024X768 to another setting 720/540 or 640/480….it becomes a mess.
    Does anyone have any suggestions?
    Dennis Leppell replied 17 years, 6 months ago 3 Members · 2 Replies
  • Ryan Spanger
    March 2, 2009 at 2:49 am
    If you are happy with your quicktime (animation) export, and would now like to create a DVD, you need to export it as MPEG2:
    – Open Compressor and add your file
    – Select one of the DVD standard settings and then modify it as follows:
    – Frame Controls: on
    – Resize Filter: Best
    Ryan Spanger
    Video Production Melbourne
  • Dennis Leppell
    March 2, 2009 at 8:25 pm
    if this is a standard definition, 4:3 DVD, your FCP settings are off.
    720×480
    DV-NTSC
    If it’s HD, 1280×720 (for 720P)
    I know it’s (the FCP settings) smaller than the Camtasia export…. the Camtasia footage gets scaled down to fit the screen (assuming this is SD video). We left Camtasia at a higher resolution to get the most versatility out of it….so if you need to zoom in on a part, the image won’t degrade.
    If you export the timeline and view the video on your computer, it probably will look like a mess….NTSC video (which is interlaced) is for TV playback, not a computer (progressive). Once you burn it to DVD, it should look exactly like it should.
    Tom, if you see this, there’s a chance I’m missing something here, or misinterpreting something. Could you please clarify….it’s sometimes hard for me to explain my workflow, especially when writing from memory (i’ve been working on a PC for the last week or so, no FCP in front of me to check), and since you wrote the book (literally), you may pick up what I’m missing.
    REGARDING WORKFLOW, I still prefer exporting a self-contained quicktime from FCP and dropping that directly into DVD Studio Pro, whereas many will say to export MPEG2 video and AIFF audio, or export self-contained, bring that to Compressor to make an MPEG2+AIFF. Exporting a self-contained is much faster than exporting MPEG2+AIFF from FCP, so you do the export, drop into DVD SP and get back to work. Exporting self contained, bringing that to Compressor for the MPEG2+AIFF, and bringing those to DVD SP is adding an extra step, since DVD SP would use Compressor internally to make the same files. Time is money, so the less steps/faster steps, the better
