Activity › Forums › DaVinci Resolve › resolutions (4:3)
  • resolutions (4:3)
    Posted by Justin Murphy on June 22, 2019 at 12:13 am
    I’m trying to export an animation that I made frame by frame in an 1920 x 1440 resolution however when doing so DaVinci does not give me an option for 4:3 standard definition so it comes out very ugly and stretched, any other pre set 4:3 resolution leaves the final product as an image surrounded by a large black box. Any fix?
    Eric Santiago replied 7 years, 3 months ago 3 Members · 2 Replies
  • Michael Gissing
    June 22, 2019 at 7:43 am
    720 x 576 is 4:3SD PAL ans is an export option. You are trying to make a 4:3 HD resolution which is non standard.
  • Eric Santiago
    June 25, 2019 at 2:17 pm
    In some cases, use a different app for final export.
    I’ve had to work in an un-uniformed scale format for days before going back to its target format.
    Most of the time I use After Effects for that.
    I do a lot of weird aspect ratio projects.
