Activity Forums Adobe After Effects resolution on animation
  • resolution on animation
    Posted by Taneil Adams on July 9, 2008 at 10:45 pm
    Hi, I’m creating a set of animated designs for my weblog. I’m render them out in AE at 23.97/30/50 in quick time format. I’m doing it in different frame rates because I can’t figure out why there are some distortions in the video. Also, I’d like to have the people who use them colorize them. I’ve used unmatted/alpha in the render options but it only allows you to colorize the outline of the flourish.
    Any suggestions would be helpful.
    Here is a link to the example. Youtube has bad compression but just so you get an idea.
    Ta Neil Adams
    Film maker/videographer
    “It is certain, in any case, that ignorance allied with power, is the most ferocious enemy justice can have.”
    -James Baldwin
    https://anewbeginningproductionz.typepad.com/introduction
    Taneil Adams replied 18 years, 2 months ago 1 Member · 3 Replies
  • Taneil Adams
    July 10, 2008 at 10:41 pm
    I was refering to the video quality after it was rendered. Because I made it I could see it but I went to full screen on youtube.
    So, I’d have to render in quick time format/RGB/Alpha/unmatted? I actually did this a few time with and with out a making the comp a transparent background.
    Ta Neil Adams
    -James Baldwin
  • Taneil Adams
    July 10, 2008 at 10:55 pm
    OK I understand what you’re saying. In the output module I don’t have the option RGB+ALPHA highlighted for some reason. I worked on a black background in the comp. I don’t know if this is the problem or not.
    Ta Neil Adams
    -James Baldwin
  • Taneil Adams
    July 11, 2008 at 12:43 am
    Yeah! Got it that was the only thing missing. Didn’t change it to animation. Thankx a lot!
    Ta Neil Adams
    -James Baldwin
