Activity Forums Maxon Cinema 4D Resolution of Cinema 4D project would not change
  • Resolution of Cinema 4D project would not change
    Posted by Antonio Silva on April 28, 2014 at 9:15 am
    I am trying to render a project on C4D but I am struggling to change the resolution of it. No matter what I set in the output section of the Render Settings panel, the image resolution would not change. It is as if the document dimensions were specified somewhere in the file other than the render settings. It might be related to the render view or something. I just can’t quite seem to locate the problem.
    I have tried to export other/new projects with this resolution settings and it would work just fine but something is getting on the way of this very document. Does anyone have an idea what could be causing this?
    Thanks in advance.
    Darby Edelen replied 12 years, 4 months ago 2 Members · 1 Reply
  • Darby Edelen
    May 7, 2014 at 7:43 pm
    What’s different about this document from the others?
    Are you using a different renderer?
    Are you accidentally editing inactive render settings?
    Darby Edelen
