Activity Forums Compression Techniques Resolution limit?
  • Resolution limit?
    Posted by Tim Kinnel on June 4, 2012 at 10:10 pm
    I am using ffmpeg to convert video from mov to mp4 and to reduce the resolution from 640×360 to 320×180. However, the video comes out at 480×270. I am using the following command:
    ffmpeg -y -i “source.mov” -vcodec libx264 -s 320×180 -b 1000k -r 15 -vpre slow_firstpass -an “output_320x180.mp4”
    Does anyone have any hints about what might be going on? Thanks!
    Cheers,
    Tim
    Stephen Dixon replied 14 years, 3 months ago 2 Members · 3 Replies
  • Stephen Dixon
    June 5, 2012 at 2:01 am
    Weird. You could try using libavfilter to do it: -vf scale="320:180"
    Stephen Dixon
    Editor, Animator, Motionographer
    Museum Victoria
  • Tim Kinnel
    June 5, 2012 at 2:07 pm
    Thanks for the suggestion, which I tried. Same result.
  • Stephen Dixon
    June 5, 2012 at 3:23 pm
    Hmm. Post the results you get on the command line
