Activity Forums Adobe Premiere Pro Resolution issues with image sequences
  • Resolution issues with image sequences
    Posted by Joe Pease on September 16, 2013 at 10:42 pm
    I am having a lot of trouble exporting a Premiere Pro cs6 project.
    My timeline is 1920 x 1080 30p
    I have AE comps and 30p footage together. The AE comps are image sequences.
    When I export out, the image sequences become very mushy and a lot of detail is lost in the each frame, the footage looks fine though.
    I exported out at the highest bit rate to test and everything looked good, the only downside is the file size was 1.3 gb for a 50 second video.
    Export settings are
    h.264
    1920-1080
    29.97
    I tried all different low and high bit rates.
    same results except the one where I exported at the highest bit rate
    I have also noticed even in playback on the PP timeline the image sequences seem low res? but if I open it up in the viewer panel the resolution is crystal clear
    any tips I would really appreciate it.
    thanks
    sorry if this topic has been covered.
    Ivan Myles replied 12 years, 11 months ago 3 Members · 2 Replies
  • Gary Alan
    September 17, 2013 at 2:27 am
    I am just guessing, go to the top Sequences-Sequence Settings and near the bottom of the pop up window Is Video Previews with format, codec, sizes, etc. I think this is only controlling what you see and not the final render output quality. Try using a better quality format and codec depending on what your system can handle for real time playback, the preview. If you have a disk raid system then maybe you can preview the highest using uncompressed full 1080p, if that is what your project and footage might be.
    HTH,
    Gary
  • Ivan Myles
    September 17, 2013 at 3:01 am
    A few questions:
    – Please clarify whether the AE comps contain image sequences, or were exported as image sequences. What format was used (PNG, JPEG2k, DPX, other)?
    – Are there any effects applied to the clips in Premiere?
    – Is GPU acceleration enabled?
    There are a variety of potential causes. Please export a short test clip (a few seconds in length) containing some of the problem footage and post the samples here. The requested encoder settings are as follows:
    General
    Format: H.264
    Maximum Render Quality: Enable
    Use Previews: Disable
    Multiplexer Tab
    Multiplexer: MP4
    Stream Compatibility: Standard
    Video Tab
    Profile: High
    Key Frame Distance: 15
    Maximum Depth: Enable
    Test 1: Level 3.1, Target BR=12, MaxBR=17.5
    Test 2: Level 4.1, Target BR=24, MaxBR=36
    Test 3: Level 4.1, Target BR=40, MaxBR=60
    If none of the files looks good, please also create a test clip with the max settings you used previously.
