Activity Forums Adobe Premiere Pro Resolution Issues
  • Resolution Issues
    Posted by Eric Mccarthy on June 26, 2013 at 7:45 pm
    I am working on a project for a high-level corporate client, and have a few questions relating to getting the best looking output from my PP timeline. I am working with two different screen captures to create a demo. One was taken from an Epiphan,the other was captured via Quicktime Pro. They have the following properties:
    Capture 1:
    Type: QuickTime Movie
    Image Size: 1024 x 768
    Frame Rate: 30.00
    Capture 2:
    Image Size: 1920 x 1200
    Frame Rate: 15.00
    Ultimately, this has to be output for two different end uses. One will be a web movie at 640×360, H.264, Max. Bit Rate of 5 Mbps. The other will be played in a conference room on either an HD projector, or a large HD screen.
    Do I need to set up two separate timelines to get the best image quality for output? Originally I set this up into a 720p timeline, but the resulting 640×360 output looked terrible. I thought that down-rezzing the clips wouldn’t hurt the image quality, but they look pretty bad.
    Any suggestions?
    Eric Mccarthy replied 13 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
