Activity › Forums › Apple Final Cut Pro Legacy › Resolution for HD in PAL format
  • Resolution for HD in PAL format
    Posted by Rob Hindley on August 16, 2009 at 7:22 am
    I have never cut a tvc in HD before. Just used to SD PAL format of 720 x 576px @ 25fps.
    What resolution should I set the project as? Is PAL Widescreen acceptable?
    And what is the fps?
    Your advice greatly appreciated as all these HD resolutions are difficult to work out!
    Erik Lindahl replied 17 years, 1 month ago 5 Members · 4 Replies
  • Margus Voll
    August 16, 2009 at 7:38 am
    Hi.
    Depends what is your goal and what you final delivery needs.
    You can edit in HD if your system is up to it and later scale down
    as PAL anamorphic or just PAL fitted in with to 720*576 from hd.
    This gives you option to output final program as HD also if needed.
    If you go and scale down to SD before edit it would be much harder to make HD edit on SD material.
    More like question of taste.
    Generally pal is 25 frames per second or 50i. 25 full frames gives you bit more movie look.
    Margus
    https://iconstudios.eu
  • Ben Holmes
    August 16, 2009 at 9:37 am
    Your first question should be to ask what the delivery specs are.
    That said, in PAL land, HD almost always means 1080i50. So that’s 1080×1920 at 25fps interlaced.
    I would suggest you read and learn more about HD before you attempt to cut anything for broadcast.
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Walter Biscardi
    August 16, 2009 at 12:21 pm
    Those specs depend wholly on what your deliverable will be. Generally PAL is 50i or 25p for HD. Either 720 or 1080.
    What does the network / client request?
    SD Widescreen is generally not acceptable as HD because it’s not HD.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    Credits include multiple Emmy, Telly, Aurora and Peabody Awards.
    Owner, Biscardi Creative Media featuring HD Post
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Read my Blog!
    Twitter!
  • Erik Lindahl
    August 16, 2009 at 6:57 pm
    1080i50 (1920×1080) is generally your safest bet since it will cross-convert to either 1080p25 or 720p25. 720p (1280×720) has it’s pros being a smaller yet quite acceptable HD format and if mixing with video shot in 720p this might be the best route to go. As others have stated however I’d check your delivery format before setting a standard.
    1080p25 is what I do all my HD work in now to be set for the future. Still all advertising in Sweden is SD PAL 16×9 FHA unless you’re doing spots for the cinemas which is 1080p25.
    Erik Lindahl
    Freecloud Communication
