Activity › Forums › Adobe After Effects › Resolution after the import (import correctly???)
  • Resolution after the import (import correctly???)
    Posted by Matteo Forni on November 8, 2009 at 2:15 am
    Hi
    I'm making a map on which a path defines a route from one point to one b: I copy the path into the preferences and imposed by the notes of rescue aicb – I copy to AE with modified paste – just try to render the text appears to be in vector while the map no, Continues to present itself as a dirty raster – I really can not understand where the error.
    Erik Waluska replied 16 years, 11 months ago 2 Members · 1 Reply
  • Erik Waluska
    November 8, 2009 at 5:50 pm
    I have no idea what this means:
    “I copy the path into the preferences and imposed by the notes of rescue aicb – I copy to AE with modified paste”
    But I think you are trying to use a map and path you made in Illustrator to animate the path in After Effects but the map appears as a raster image instead of a vector image.
    Was the map created in Illustrator? If so, did you enable “continuous rasterization” for the map layer in After Effects? It’s the little icon that looks like a sun.
    -E
