Activity Forums Apple Final Cut Pro Legacy Resolution 864×648?
  • Tom Brooks
    February 25, 2008 at 3:50 pm
    Are you producing After Effects for use in a 16:9 edit? Did they mean 864×486 by chance?
  • Todd Carter
    February 25, 2008 at 4:10 pm
    I think it is just a straight final cut edit. I did ask if they meant 486 but, haven’t heard back. Assuming that is the case, that still is a non-standard size. So, how would you recommend I setup my capture and sequence settings for real time processing? thanks.
  • Todd Carter
    February 25, 2008 at 5:19 pm
    I talked to them, and it is an AE adjustment now. i feel better. thanks for your help.
