Activity › Forums › Adobe Illustrator › resizing web logos and pics
Posted by Jason Shepard on October 10, 2005 at 3:09 pmI am constantly receiving images (logos and pics) captured off the web, and I hear that you can resize them ( make them vector) in Illustrator to make large enough to edit with in Avid on anothe NLE. I have not been able to figure it out.
Any feedback is welcome. Thanks much.Graham White replied 20 years, 11 months ago 3 Members · 4 Replies -
Richard Harrington
October 10, 2005 at 6:26 pmYou’ve heard wrong…
Insist the client give you an AI or Vector EPS…
Blowing up web logos is bad news all around…
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.comedit – produce – direct –
Jason Shepard
October 12, 2005 at 1:27 pmThanks for the response. I was mis-informed by an Adobe presenter at NAB 2005.
do you know of anything that does allow you to re-size or convert non-vector to vector?
We do insist and in a perfect world people would take heed, but that is not always the case.
thanks
Jason -
Richard Harrington
October 12, 2005 at 1:58 pmWhiel there is a trace function ia AI 2…. it does not work well on pixelated artwork. It is meant for scanning in hand drawings (at high-res) and converting them to vector.
Blowing up small raster artwork just produces garbage. The only thing I’ve ever down with reasonable success is take an image and resize exactly 200% with nearest neighbor.
While I use Genuine Fractals a lot… I use it to upres video frame grabs. Logos off websites are often 75 pixels across… you need eight times that for a video graphic… so pretty damn near impossible.
You’d have better luck getting a business card or brochure and scanning… I’ve also mined websites for PDFs which often have high-res logos in them
Graham White
October 13, 2005 at 1:21 pmFlash has a trace bitmap function that is not too bad, you set it to trace every pixel,
save as a .ai ver 6 file and then rescale in illustrator, and export there to another image format. It can be pretty clean, but you are of course just getting an expanded version of the web image, with no increased detail.
