Activity Forums Apple Final Cut Pro Legacy resizing stills in fc pro
  • resizing stills in fc pro
    Posted by Jens Kuehnemann on October 19, 2008 at 6:52 am
    hi !
    i would like to use still images in a final cut pro project.
    unfortunately does fc always try to fit the images fullscreen. so if the image does not have the correct ration i end up having grey frames left and right or up and down. the image also is always placed in the center of the screen. is there any way to move the image where i want it to be and scale it like i want it to be scaled (like the transform oprtion in photoshop for example)
    cheers
    jens
    Alan Smith replied 17 years, 11 months ago 4 Members · 5 Replies
  • Tom Wolsky
    October 19, 2008 at 2:44 pm
    What version of the application are you using? In the current version there is a user preference which determines how images are handled when edited into a sequence. It defaults to fit to window. To scale and reposition, the simplest way is to switch the View popup in the canvas to image+wireframe. You can then drag a corner to resize the image, drag the image around the screen to reposition it, and many othe things, which you can read about in the manual or other training materials.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Jens Kuehnemann
    October 19, 2008 at 6:56 pm
    thanks for the answer.
    that was what i was looking for.
    cheers
    jens
  • Andy Shnikes
    October 19, 2008 at 10:51 pm
    wow, that would be convenient! A drag and scale within the window, would greatly reduce time spent fumbling with the numbers, i suppose one more reason to upgrade.
  • Tom Wolsky
    October 20, 2008 at 12:46 am
    These have been FCP capabilities since v1.
    All the best,
    Tom
  • Alan Smith
    October 21, 2008 at 2:57 pm
    Another thought is that by using Photoshop, you can have Photoshop resize the images to your preferred dimension using an automate function. When you import the images into FCP, all the images will have the same dimensions and fit the screen as you want and not as FCP thinks you want.
    Alan
    Alan Smith
    Media317
    Check out my blog – https://media317.com
