Activity Forums Adobe Premiere Pro Resizing Sequences in PPro CS6
  • Resizing Sequences in PPro CS6
    Posted by Brad Weiss on August 29, 2012 at 1:04 pm
    Morning Folks!
    I’ll get right down to it: i’ve been editing a multicam project from a live concert that i shot back in March. The footage was a mix of DSLR footage (1280×720 60p) and Standard Def handycams.
    When i made my first sequence i (unfortunately) used one of the Adobe 720 presets. After bringing in all my footage and syncing the multiple tracks with pluraleyes, i would copy the sequence, select which song i wanted to focus on and cut away the excess footage, nest the layers and MC edit from there.
    Meeting with a fellow editor last night i realized i had made a grave error – the original 720 preset i had used was a 720 x480 sequence, and not the 1280×720 as i had hoped.
    Since PPro doesn’t allow me simply to resize a sequence (anyone know why that is?) I am looking for a work around to maintain these edits and put them into a 1280×720 sequence but have no idea where to start.
    As i have a dual boot system and access to FCPX trial, im wondering if i can export the 720×480 sequences as XMLs and load them into FCP resize them to 1280, then re-import these XMLs back into PPro into a 1280 sequence. Has anyone tried this? Can anyone offer an easier solution?
    Next time i’ll make sure to choose sequences settings the way im used to – by manually setting the dimensions myself!
    Thanks.
    Brad
    Paul Neumann replied 14 years ago 4 Members · 4 Replies
  • Ann Bens
    August 29, 2012 at 5:17 pm
    Make a new sequence,
    copy from old sequence and paste into new one.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Eric Jurgenson
    August 29, 2012 at 5:19 pm
    Create a new sequence with the proper settings, copy & paste the original timeline material to it.
  • Brad Weiss
    August 29, 2012 at 6:41 pm
    Thanks for the response Ann & Eric.
    So my multicam sequence copy and pasted inside a new 1280×720 sequence, but then isn’t the nested sequence the multicam cut is built on is still only 720×480.
    I believe i tried this last night but when i dropped the footage into the new sequence and tried to scale up footage it was restricted to the 4:3 aspect ratio of the original nested sequence and will not fill the frame.
    If i copy my nested sequence into the new 1280×720 sequence (which i have begun doing) i would have to redo all my multicam edits, wouldn’t I?
    Or is there a way to re-link which nested sequence i am pulling from?
    To Clarify:
    Me:
    Sequence 1 – Sync Map/Nested Sequence of all footage (720×480)
    Sequence 2 – MultiCam Edit based on Sequence 1 (also 720×480)
    Your suggestion (if i am reading you right):
    Sequence X – Resized sequence (1280×720) with Sequence 1 footage copied into it. Then…nest footage again and re-cut the multicam?
    The step i’m trying to avoid here is the re-cut of the multicams for each song/track if it can be avoided.
  • Paul Neumann
    August 29, 2012 at 8:34 pm
    Right click…”scale to frame size”.
