Activity Forums Adobe Photoshop Resizing an Image without losing aspect ratio in photoshop 7
  • Resizing an Image without losing aspect ratio in photoshop 7
    Posted by Brian on June 22, 2005 at 1:45 pm
    I am wanting to keep an image at 640×480 and don’t want to lose my aspect ratio. But when I change it to that setting, the picture looks fat and squashed. How do you make a picture that was taken at a larger resolution fit down to 640×480????
    Andrei Lutic replied 21 years, 2 months ago 2 Members · 1 Reply
  • Andrei Lutic
    June 22, 2005 at 3:52 pm
    Usually, if you want to keep the same aspect ratio for your image, you must check the *constrain proportion* in the *image size* dialog. If your bigger resolution image has other proportion than 640×480 (4:3) it’s naturl to don’t look alike when you make it 640×480.. maybe you must crop it a bit 🙂
