Activity Forums Adobe After Effects Resizing a tracked composition
  • Resizing a tracked composition
    Posted by Mauro Moreira on October 25, 2010 at 6:16 pm
    Hello guys, i`m having some troubles when i resize a 1920:1080 composition with tracking information in some nulls objects.
    I need to resize to 720p and mantain the tracking points, because i`ll export a XFL file with the tracking information to flash.
    Mauro.
    Kevin Camp replied 15 years, 11 months ago 2 Members · 1 Reply
  • Kevin Camp
    October 25, 2010 at 7:25 pm
    i’,m not sure how you are doing it now, but this may work…
    duplicate your 1080 comp and add a new comp sized solid. select the nulls with the tracking data and parent them to the new solid. in the comp settings, change the comp to the new comp size (i assume 1280×720). select the solid layer and choose layer>transform>fit comp height and then delete that solid.
    hopefully, the nulls’ data will now be relative to the new comp size.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
